txstang84
The amount of work they put into those heads would cost you as much as a new set of EQs completely assembled. If you've never ported iron heads before, it's a good bit of work just cleaning up the bowls. They ported stock 318 castings to 360 port window size, did a good bit of bowl work after cutting the seats out and using a bowl hogger...there's a LOT of work in those 302s.
