like_A_pike
that's not factory
First off this is a 68 barracuda and the dash has been "remodeled" at some point. The "fabricator" left three slots and that's it. The control unit is in a box. I have a manual but it only shows how the cables are conected at the heater box. I need to know how they connect to the control unit. The top sliding lever has two pins. As you slide it one cable must max out and the second takes over. What is that lever doing???? Whats the bottom one do? The fan switch has three positions. Can you tell me what they are from left to right. I assume left is off, middle is on, right is on and faster??? Finally, has anyone taken one of these apart and know where you can get the plastic pins, push stops, and cable retaining clips??? thanks
l_A_p
l_A_p
