moparmat2000
Hi Y'all
I have a spare tire board metal cup that holds the board in place. When i can find these they always seem to be deeply pitted from corrosion. Since these only exist to keep the spare tire cover board in place its not really a critical structural item, plus theres enough metal left that it will work without failure for its task, why not try to fix it?
I decided to sandblast the part to completely remove all the corrosion which left a pockmarked texture, and a few tiny pinholes, then i proceeded to apply JB weld with a cut down acid brush. When the epoxy was dry, i sanded it smooth with an air powered DA sander and 180 grit sandpaper, and reapplied more JB weld to the low spots. Once dry i will sand smooth and apply some epoxy primer, scuff and paint. I will add more pix as i progress through this. Hopefully this will help other people to be able to save stuff like this that is not being reproduced.
Pic #2 shows the bottom side of the cup with first layer of jb weld sanded, and pic #3 shows a small reapplication of additional jb weld to the low spots on the bottom side of the cup. Once smooth, i will apply a good epoxy based etch primer
Matt
Matt
