Retainer size for np435?
71dusterdan
rockford il
So still searching... Found an np435 bellhousing, going to see if my 833od can be made to work behind this bell and then bolt up to my 5.9. The issue I am having is trying keep my 833, yet also have my magnum beer keg fuel injection. I found a post on moparts, where a guy made it work with a redrill and a metal plate. I found a bell, should have it early next week. The poster claimed the retainer covers were the same size. Can anybody give me the size to a 435 retainer? Thank you
The bolt pattern is completely different.
The OD833 and the NP435 both share the same 5.125" sized bearing retainers but as Rusty pointed out the bolt pattern is completely different and there's not enough meat on a truck bell housing to drill for an 833 bolt pattern.
Why not simply use a small block OD bellhousing? There are tons of them out there.
You can change the bearing retainer to a 4.8" in a OD trans, this will open up your options.
Check 80-85 dodge 2wd trucks in the junk yard.
