Mopar to ya
My 408 and 200R4 install are well along the way. We had a hard time getting the motor in and had to loosen the bolts on the brake booster to get it in. It barely clears and under torque, the left side is going to try and come up, even with a torque strap. That being the case, I am taking off the MP valve covers from my 318 and using those instead of the tall Moroso aluminum covers that are on the motor. I already checked, and they fit - valve train height is not an issue. That will leave me a lot of clearance. I have to notch the Super Victor intake a biy to get them to fit, but no big deal. Which brings me to my next thought. The Super Victor and it's long straight tubes are great for higher speeds, but everything about this car is geared to getting there quick, not top end. Also, the SV has no mount for the coil, throttle cable, temp sender, etc... None of which are a huge issue, but I have the Eddy RPM Air Gap intake in my 318 now, and it has all of those things plus I think the motor and car would be better served by this intake over the SV. What do you think? Am I crazy or am I on the right track here?
