rich rough idle secondary float seems dry
barebonesdart
Member
hamilton
unknown holly carb (list 7646 3236 on choke tower body)8515 on main body of carb ahead of front float cover,elec choke starts good when adjusted to full choke but floods at every stop i removed float site gas pouring out when i first removed float adjust top screw pressurized fuel came out. secondary float seem dry nothing at site hole(does car have to be running to check sec. float?)I would like to know cfm #s and maybe revert back to cable actuated choke. am i chasing my tail with this carb and should i maybe spring for a known good proper sized carb if so what would you all recomend
1970 swinger dart 340ci
1992 jet boat with 1972 440ci bored out 446
960 heads
holly double 850cfm on edlebrock high rise drag intake
1"riser
accell high fire
chrome brain box
zommi headers(loud as hell)
Has it been sitting on the shelf?If you been working the choke stat adjustment,might be part of the problem.Do you have it hooked up, to key on power?
the feul system is what ever came with the car theres a pro stock intake no engine mods that i know of bearings and crank replaced in the last five years oem
960 heads
1"riser
accell high fire
chrome brain box
didnt know I had to key on to adjust choke i was manualy turning with key off maybe this is operator error issuse (cap rotor plugs and wires all new)but car was the same before
960 heads
1"riser
accell high fire
chrome brain box
zommi headers(loud as hell)[/QUOTE]
Needs to be done by a old school guy.What intake,do you have?Pictures,would solve this absolutley!
Did a little research and only thing i came up with is a reference to Jeep and AMC 360/401 stuff. Not sure if it was OEM on anything, but kinda looks that way? I have a feeling it's a single feed, vacuum secondary 600cfm ish type carb. If this is for your 340 i think you could do better, but that carb should be able to run decent for now. May need a rebuild and i agree, pictures would help to identify what it really is.
i found the upload tools here are the best pics i could take not bad for the camera that has a phone attached
Rebuild it if you were not to far I could do it with my eyes closed ,I love holleys.you do need it running to set the floats.if you remove the site plug and fuel pours out its to high needle and seat set wrong or dirt is holding it open,also if the rear has no fuel wrong adjustment or your transfer tube is block no allowing fuel to get to the bowl.our old friend Strockerscamp did a how to on rebuilding a 600 read through and you will get the jest of it.
replaced holly with a carter 650 ran perfect for 3 / 4 days then the underlying problem showed its self was dirt and old gas slime from tank I tore down carter carb and cleaned it out put filter in front of carb has been running fine ever since thank you everybody for your help
Did you drop the tank to clean it out?
Holleys don't run well with dirt in them either. Not a carb problem from the start if you were to ask me.
