plyduster73
I think I want to go with the 1 pc torque thrust 15's.
Front 15x7 -6mm
Rear 15x8 -18mm
I just want the wheel wells filled up and the front and rear tires to appear equal when you look down the side of the car.
I have disc brakes and am leaving the rear leaf springs in the factory location ( if that matters)
Will these offsets make the front and rear tires stick out equally?
Will I have trouble with rubbing in the front with this offset
Also, does this seem like a dumb combo?
Thanks
Front 15x7 -6mm
Rear 15x8 -18mm
Thanks
