Anyone experienced setting up rear ends? I'm assembling a narrowed 9.25 axle for my '71 Duster. The problem I'm having is no matter what pinion shim I use the drive side pattern stays low on the toe. Backlash set within specs at 6-10 thousandths.The instruction booklet I have with the Auburn Sure Grip [Yukon] says to ignore the heel & toe pattern & concentrate only on the pattern from root to crown or sometimes called flank to face because that guarantees correct pinion depth.That I agree with. An deal heal to toe pattern cannot be achieved without pinion bore alignment machine work. I'm a little too paranoid to set it that way for fear of gear noise. I've "literally " set this thing up 101 times! HELP!!!!!!!!!!!!!
