rocker arms
ScottieB007
Member
Columbia Kentucky
What is the main difference between stock 1.5 rocker arms and stock replacement Mopar performance 1.5 rocker arms? Are they better built, closer to 1.5 across the board as opposed to factory stock and finally are they worth the buy? Considering im not going with roller rockers ? I have a 77 318 with a 340 cam , four barrel intake and carb , 1.60, 1.88 valves eddy springs with other head work and headers also 9.1 compression . just trying to do the things dodge should have done if it were not for emissions standards of the time. Thanks for any input
MP sells/used to sell? Heavy Duty stamped rockers. they were the same ratio 1.43 with variation BUT with thicker material.
Don't think you need them with a stock 340 hydraulic cam. Stock 340's didn't have them.
