Dezduster
Quick description
360 block decked to 9.600, .040 felpro blues, Indy rhs X heads by Brian at IMM, Hughes 1.6 rockers, Hughes retro hydraulic rollers lifters 5321 and Hughes HER2836ALN-10 cam.
Following Hughes instructions checked the sweep that looks great with no shims, it sweeps from 2mm from intake edge of valve through center to 4mm towards exhaust side. I tried a .040 shim and that started the sweep in the center of the valve. I will likely try the .020 shims to see if it will sweep the center 2mm of the valve tomorrow morning.
Adjusted the checking lifter to 2.160 which is the operating length I came up with, with 3 turns in on retro roller 2.160 is my best figure with calipers and micrometer. Set my rocker ball stud protrusion to the .320 figure as recommended and adjusted pushrod to take up slack. Do a lift check and .532 supposed to be 544. I follow the directions and adjust the push rod shorter and extend rocker ball stud again and again and yet again. So I finally get my .543 lift but the ball stud is protruding .520 and like 5 threads out of the bottom.
So where the bleeping bleep did I bleep up. Surely running the ball stud out like that will break the stud. If I go the other way I loose lift.
