I finally got to hear the engine with full exhaust on. I noticed a tapping coming from the engine and shut it down.I pulled the drivers side valve cover off and found the rocker 3rd from the back was loose. I took it off and inspected it and all looked well. I put it back on and started the engine. The noise was gone but then I noticed that there was no oil coming to that rocker. All the rest were getting plenty of oil. The engine is a 360 with magnum heads and 1.6 rockers. The engine sat for 2 years after being built.
Is it a clogged oil passage? Something else?
Any and all suggestions will help.
Jack
Jack
