Rockers-inner -outer- difference
TF360
Florida
Trying to figure out which rocker I need. The flat piece that runs under the door from in front of the rear wheel to the front fender area. Its like 3 1/2 inches wide. Which rocker is that? Thanks for any help!
Outer if I understand your question.
Post a pic, basically the outer is the one you see looking at the car from the outside, the inner you can see it from underneath the car.
Thanks--So does the outer wrap underneath into a flat section About 3 1/2 inches wide that faces the floor?
Yes. just hope your inner isn't as torn up as mine was
Ok thanks Wayne, so your inner is torn there and that is where it attaches to the outter
