I have a set of 527HND's on the shelf, and they do have tangs. I guess to be safe I should get a set of 527P's.
You can use them. The tang doesn’t do anything but line the bearing up side to side. The crush between the bearing shell half’s keeps them from turning.
Zero cause for concernThanks. I was concerned about the unused dowel hole on the bearing half.
Thanks Mike. Kim
