ValiantKevin
So my 360 has been machined to a deck height of 9.580, I already have new in box Speed-Pro Hypereutectic Pistons H116CP30
Details (Sealed Power H116CP30 Speed-Pro Hypereutectic Pistons | Summit Racing)
Part of me thinks I should be fine reusing the stock rods, I would for sure be fitting them with ARP bolts if I did.
Question for the engine builder math wizzes... Given what I already got, what options do I have?
If I use the stock crank, am I stuck with the 6.123 length?
(Yes I am aware of the CR ratio factors depending on the heads chamber cc I just am unsure if I can even consider using the longer rod in the factoring of my CR)
Second question, if I went away from the stock crank (doubt I will) but thought I'd see what factors I might not be considering that I should... such as are there other stroke/rod combos I should strongly consider?
Such as if I was to go with a new crank, there any "secret awesomness" I should be aware of? Such as going with a shorter stroke with longer rods kind of combo?
Or should I just stay with the stock crank & rod lengths given what I got?
