[WANTED] Roller cam for magnum
Ceedawg
Va
Looking for a mild roller cam to fit a Magnum 5.9 and to use the fuel pump eccentric or if just the cam I can buy the add on piece from Mancini. .480 lift 269 duration range
You can use a LA cam in a magnum, just use the extension piece. Aftermarket cams for the magnums are pretty scarce.
This is coming from my experience on a 318 though, not a 360.
Stay away from the nose adapter... Hughes sent me one because they shipped me the 'other' cam... What a POS, I don't like the way the keyway works in the kit and made my own keyway from one I bought at a hardware store...
Buy a roller cam with the nose for the fuel pump eccentric, much less head aches....
FWIW I haven't had any problems with my adapter. I'd have to pull out my receipts to check, but I think the adapter I bought was the one from Hughes. I haven't had any issues with it yet. Many spins to 6400RPM at 400hp+. about 1.5k miles on it so far...but I don't have a fuel pump eccentric either.
