gzig5
I've made lube saver style lifters, grinding a flat on the side
How wide/deep did you make the groove? Shouldn't need to be much. I've got a new set of SFT lifters with no band that I want to do that too. My thought was to setup in the v-block and grind a flat a couple thou deep, should be .010-.015 wide but I haven't looked at the math. Should provide a nice controlled leak of oil to the face of the lifter.
