Roller rocker copper stand shims
hwy2
texas
I have need to shim rocker shaft to get roller tip to seat on valve stem.. i have used copper for shims will this work meaning copper shims? I had to make some none are made for these rockers yet.
Call Mike at B-3 Racing. If you are serious about proper placement and cost is good for what you will have.
Ill call them Tuesday. I looked them up last week. Thanks. I can see it will work when I push on rocker to meet valve. Did not seem hard to make. I got it to all line up fine.
