T56MaxTorq
Assembling the engine after a cam swap on a 360. I find a cracked rocker shaft between #1&3 cyl. Unacceptable, I find a replacement shaft but it would be on back order for over a week. Hughes banana groove shafts? They look good but I have an old set of Cat roller rockers which have roller bearings (I think) that ride on the shaft..would the grooves knurl up the bearings? I may just go in on a set of hughes aluminum rockers if finding another stock shaft takes a while and I'll just slave the Cat rockers to a roller cam 360 I need to build.
