Btw, which springs does your trickflow heads have, the pac 1.46?
Here's the specs. They are pretty stout for the standard spring.
Valve SpringsStandard: 1.460” O.D. Dual Spring (TFS-16893-16)
120 lbs. @ 1.900” Installed Height
394 lbs. @ 1.175” Open
390 lbs./inch Rate. 650” Maximum Valve Lift
Option 1: 1.550” 138 lbs. @ 1.950” Installed Height, 430 lbs. @ 1.250” Open, 420 lbs./inch Rate. 680” Maximum Valve Lift
Option 2: 1.560” 240 lbs. @ 2.000” Installed Height 600 lbs. @ 1.280” Open 500 lbs./inch Rate. 700” Maximum Valve Lift
For Comparison.....
Compcams spring for their Magnum and Xtreme Engery Solid roller cams < 308R and <XR286R
1.489" 165lbs @ 1.800", 385lbs @ 1.200" Open, 1.100" bind, 367lbs/in, Spring Part #914
For their Hyd. Rollers they use,
1.430" 121lbs @ 1.800", 343lbs @ 1.200" Open, 1.150" bind, 370lbs/in, Spring Part #987
Lunati Voodoo Solid Roller <255/263@ 0.050"
1.550"
200lbs@1.800" ,
596lbs@1.100" Open, 1.050" Bind, 566lbs/In, Open Spring part# 73117
Lunati Voodoo Hyd. Roller < 713k, 243/
251@0.050"
1.437"
115lbs@1.700",
336lbs@1.150" Open, 1.050" Bind, 402lbs/In, Spring Part# 73195
