carcrazyguy
In the area where the roof meets the drip rail area on a 70 Duster, was there any type of sealer used from the factory?
Can someone please post a good closeup of this area. The bodyshop that is working on my car is asking if I have any pics of the way it should have been from the factory. Somewhere along the line, someone scraped it off on my car.
Don't have a 70 but 64 & 67 is like the pics, hope they help!
Drip rail sealer, sells at NAPA too!:cheers:
Good luck with the body man needing help with drip rail sealer!
A two-part self leveling seam sealer is the way to go. 3M and Lord Fusor make them. For me, Fusor #129 came the closest to the original material in color, texture, and hardness. I filled it to about 3/16" below the gutter edge. You can sand the stuff if need be. I'd tape off each side of the gutter before applying and then pull the tape for a clean edge.
