Rotor Suggestions (I'm sure I am overthinking this)
You know what you are correct it shows my ignorance. It was a 57 chevy 210 car he was working as well. Now that Im thinking about it he did have the the k member I believe its called and some other suspension parts hanging up. I have a lot to learn!
No sweat. Just pokin a little fun. Nobody knows it all and we all started somewhere. If you want to get REAL technical, you can say frame off regarding a Mopar, because it does have a front K frame that supports the front suspension and engine and it certainly can be removed.
No worries! Your exactly right gotta learn to crawl before we can walk!
Not looking to really upgrade this is a numbers matching stock car. Has a 318 in it. Just looking to replace the original rotors calipers from the original conversion my father did.
It’s not a numbers matching stock car if it has the 73+ brakes on it. Really though it’s semantics because mopar didnt build the brake parts anyway. If I were you, I’d look up calipers, pads, and rotors for a 73 dart on rock auto and order all new stuff. It’s cheap, easy, and the quality of the parts will be similar to what you’ve got on there when they were new.
