Rough idle / engine rough 2000 rpm help!
lucahemi
REBUILT THERMOQUAD/ STOCK CARB . THE ELECTRICAL SIDE IS ALL NEW . IGNITION BOX/REBUILT ELECTRONICS IN DISTRIBUTOR / NEW WIRES / FRESK REBUILT MOTOR/ NEW COIL. NEW BALLISTOR. wHEN YOU RUN THE ENGINE AT 2000 RPM IT ACTS LIKE A COUPLE OF CYLINDERS ARNT FIRING. I TOOK A SPRAY BOTTLE AND SHOT FUEL OVER THE CARB AND IT SEEMED TO CURE THE PROBLEM . I ASSUME THE ELECTRICAL SIDE IS OK. I FEEL ITS A TIMMING ADVANCE OR CARB ISSUE . DOES ANY ONE HAVE ANY IDEAS
Just my opinion, but if you sprayed fuel at the carb and it "cured it", you may have a vacuum leak. I'm sure others in the know will chime in.
Verify timing first. I'd set it at around 14* initial to start.
