James Kelly
New Member
My 318 recently started popping out the exhaust while idling in park, and when I put it into gear it barely idles at all. I tried driving it around, and it will not rev at all, it sounds like its misfiring every other cylinder. The engine has a double roller timing chain that I installed last summer, and im certain it was installed correctly. I put a vacuum gauge on a full manifold port and it reads steady while idling in park at around 24hg. when i put the car into drive it stumbles and acts like it wants to stall out. While in the drivers seat it almost sounds like a knocking/grinding noise coming from the floor, but in the engine bay it sounds pretty normal. I even my a socket extension on the valve cover and held my ear on it to make sure there wasn't any internal knocking. I pulled the valve covers to make sure all the rockers where moving, and they were all normal. I had just had the heads machined last winter. every cylinder was within 3 psi of 120. I have the initial timing set at 18* with a FBO lockout plate inside the distributor, and the total timing is around 32*. I pulled the plugs they are all optimal except for 1 which was a little bit darker, but didnt look like it was dark enough to cause any issues.
Here is 3 videos put together, the 1st is it idling in park while its warm, the second is after I tried to drive it around, and I put it into gear, and the 3rd is in gear with the parking brake on. The idle is high becuase it wont run in dirve without the idle being jacked up a bit.
Thanks to anyone who can help, i'm 19 and i'm trying to learn and do all this by myself, i'm the only car guy in my family.
