Routing steel brake lines
Joe Dart 69
New Member
Northwest Jersey
Hello all,
I am building a 69 Dart from a empty shell. I am running new steel brake line however the kit did not come with instructions, only identification on the lines are color coded caps on the threaded fittings. No description on where or how they run under the body. The kit came from In Line Tube, their web site was not help identifying where line run.
Does anyone have pictures or a routing chart for the steel brake lines?
Please help Thank you
On my '72 from the engine bay, the line runs along the inside of the driver side frame rail, through the transmission crossmember then angles over to the driver side rocker pinch weld and runs back to the rear, wraps the rear frame rail in the wheel well then terminates into the bracket where the rubber line connects.
That helps a lot, thanks
