dennday67
As the title says I have a complete running 1968 225 slant six and 904 also bbp 7.25 with good 10" drum brakes. The motor has 2 year old water pump, fuel pump, ngk plugs, electronic distributor with homemade HEI setup, motor mounts, drool tube seals, cap, rotor, wires. I've installed an aluminum 2 barrel intake that I've reworked and installed a rebuilt Holley 350 with adapter. Homemade throttle bracket to work with factor cable and lokar kickdown (included). Chrome and stock valve cover and chrome 14" air cleaner. I've recently flushed and filled the 904 with new filter and shifts good. Motor and transmission has no leaks and doesn't smoke. What is not included is the alternator and starter. Make me an offer including email and I will send more pictures and video of it running.
