mjmmike
Member
Compression checked with all above 100, drove around yard forward and reverse fine, engine sold air cleaner to pan $400, Radiator to front u joint including AC compressor pulleys, fan and shroud $700, Motor was replaced in the 73 duster it sets in and numbers are milled off the block , it does have spark plug tubes, will remove and set on your truck. Maryland 21918
