Hi all,
With the help of some great FABO members, I have been trouble shooting my charging problems in my 64 Valiant convert with a 80's 318 for the past couple weeks. I Replaced everything that cold be replaced only to find a bad series of splices in the field wire connection to the voltage regulator as the chief cause. Now I'm knocking down 13-14.5 volts at the battery and voltmeter at even at low idle.
Everything seemed fine. Then she started to run rough and die at low idle. Seems like she gets starved. Seems like there's plenty or fuel, she runs strong at high revs but let her get down and she coughs to a stop. To get her going again I have to floor the gas pedal and crank for a good 10 to 15 seconds.
To my knowledge I didn't touch anything else in the car except things connected to the charging issue.
With Mopars in the Park coming this weekend, I'm getting desperate to get her going. Any thoughts?
Thanks in advance.
Thanks in advance.
