Pawned
N.R.A. Lifetime Member - And damn proud of it
When I bought the car it looked like the picture in my signature. I noticed a few bubbles in the paint. I had tapped them with a hammer and they did not break open.
The paint job was pretty awful. The paint peeled off with a razor.
I decided to repaint the car and investigate the rust they covered up. The car must have sat on the ground in someone's back yard or in the desert. All the rust I found was relatively minor and the rust was inactive. The rust was only where the car met the ground.
The few rust spots are a pretty easy repairs, but the right rear quarter panel (pictured) is another story. The previous owner obviously pushed a couple pieces of metal behind the panel, thru the trunk, and then secured it with a (very) few tack welds. Then they applied about a quarter inch of bondo to it.
My question, should I secure (weld) the metal behind it and then skim over it with bondo, or should I cut the panel out from the marker light down and then weld a metal sheet behind it, then add filler to even the panel?
