DARTLARRY
Well I Was Just Getting Ready To Install New Leafs, When I Discovered That Rust Had Taken Over The Frame Rail Where The Perch Bolts On. After Half A Day Of Cutting And Welding It Has All Been Repaired (i Hope ). The Problem I Have Is I Would Like To Try And Clean The Inside Of The Rail So This Doesnt Happen Again. I Can See Inside And There Are Big Pieces Of Rusted Material Inside. I Have Tried To Blow Them Out With A Compressor, I Got Alot Of Dust But The Big Pieces Wont Come Out. Has Any One Here Had This Problem And If So What Did You Do. Thanks In Advance For Any Help.
