[Found!] RV-2 compressor mounting brackets for '76 360 w/ aluminum water pump.
Jason Wenger
Active Member
Rockford, IL
Rating - 0%
0   0   0
I already have a good RV-2 compressor from the original slant 6 but those brackets are obviously useless to me.
Looking for a full set of AC mounting brackets that will work with this motor.
We have either a 76 or 77 360 out of a Cordoba or a Magnum. This motor has a cracked block, but the RV-2 compressor brackets are still there, and complete. They are clean brackets also.
Bump. Still looking for a set of RV-2 brackets for a 360 w/ aluminum water pump, and also a 3-groove crank pulley.
