Have an a/c rv2 compressor with bracket and pulleys for a 60's era setup I believe , was told for a 68 model ,the pulley an tensioner turn freely but I would replace bearings while there out as there old, the bearings are just pressed in it appears as I took apart to clean an paint , doesn't look to hard to replace with new sealed bearings . Looks like the compressor does appear to have been rebuilt or a replacement at one time if the sticker on top is correct , turns freely and had oil in it when lines were removed , New prices , will sell the bracket set for $75 ,,the compressor by itself for $70 ,,belt pulley with coil $50
