[FOR SALE] S/B 370 complete engine
Mtn Thunder
Tehachapi
370 cu. in. S/B for sale. (.020 over 340 with a 3.58 stroke). Engine is completely rebuilt .
Components are: 7/5/70 block (no vin #).
Scat 340 main 3.58 stroke cast crank- Eagle H-beam rods- KB 107 Pistons and rings.
Clevite bearings. Block has been decked and align honed. Machine and balancing done at Valley Head Service in Van Nuys.
Cam, lifters and push rods are Comp Cam. Cam is the XE274H. Milodon gear drive puts the cam in motion.
Heads are rebuilt X heads with matching valve springs. Hardened seats and new guides. New 2.02-1.68 valves. Mancini roller tip rocker arm kit.
Intake is a Weiand Stealth with a Holley 750 vacuum secondary carb and Mr. Gasket air cleaner.
Distributor is from Firecore.
Stock 340 oil pan.
New water pump.
New Summit Pro Street Balancer.
Engine has been run on a run stand as seen in pictures. Ready to install in your car.
Does not come with flywheel or bell housing. Pulleys, fan, alternator and brackets not included.
I prefer to sell to some one who can pick it up in person. That way I can run it and discuss any questions before you buy it.
I will ship it but at a considerable expense as I have to go 40 miles to a trucking company to ship. (Bakersfield)
Price is $5500. I will sell minus Valve covers, carb, and distributor for $5100.
I am in Tehachapi, Ca. 93561. I am close to HWY 58, so if your passing through we can make arrangements to hear it.
PM with any questions.
Mike
Final tuning is done. Idles at 850 RPM. Throttle response is crisp and returns to a clean idle quickly.
No leaks. Gear drive is noticeable but not annoying.
Final compression ratio is 9.4 to 1.
ARP main studs,and intake bolts. Also ARP bolts for the rocker arm hold downs.
Since I have no local interest I have decided to try to sell elsewhere.
I will now crate and ship to any destination. Buyer pays and arranges shipping.
I can ship from Lancaster Ca. or Bakersfield Ca. or if the right truck is sent (lift gate)
I can ship from beautiful downtown Tehachapi. 93561
Mike
No. Numbers are not important to me. I just wanted something with decent power for a cruiser and a nice lope at idle. I wanted to use some parts I had around like the rods, over kill I know, but I had them.
At .020 over this block still has room to grow in the future.
