same old question
zigs
Yakima, Washington
O k . I've seen all the tires and wheels on the tire and wheel thread.
I have a 68 Dart that is having the mini tub and moving the springs in 3".
I'm wanting to go with 15" Cragar deep dish all around. what should I run up front and what is the widest I can get away with in the rear. Assuming all Darts with this change in the rear are the same. I would like to order tires and wheels while work is being done or would it be smarter to wait and get actual measurements.
well if you do the SS conversion and beat the inner part of the wheel well (rear) flat to the frame along with the wheel well cut out you can to a 30x12.5 15 no problem...
for period correctness we run BFG silvertowns 6.70 15= 28" tall (biasply) with Et Streets on the rear (traction)
