saying hello and thanks.
squeakypedal
Member
ca
hey all,
just popping in to say hello for the first time and wanted to say thanks for the info garnered from all the posts, linkages, and tech articles. i'm currently finishing up my 73 rust bucket (seventh a-body in my long run of mopars) and finally decided to introduce myself. once again, thank you forabodiesonly!
cheers
thanks for the responses. okay, you asked for it:
started out as a 225/3 speed manual column shifted, small bolt pattern 4 wheel drum brake daily driver parts car. now is k member swapped, 24 inch roundy round style radiator, with 40 over 318 backed with floor shifted four speed, big pattern disc brake swapped, 8.25 rear big bolt pattern rollin' on 77 cordoba wheels, front and rear sway bars and poly everything. tube uppers, reinforced lowers, firmfeel fat strut rods, 1 inch torsion bars, hd leafs and helper coil rear shocks, subframe connectors and the cheapest jeep seats i could find.
