petreed150
Well went to machine shop and Him and I came up with new plan!Now it has .030 over kb107 pistons zerodecked,Eddy rpm 60779 heads,AirGap,Comp Ultra Pro Magnum roller rockers!The cam is XS274 cam with 502/511 lift and 236/242 @50 and holley 650dp!Compression will be 10.5-10.8!Heads will be flowed and bowlblended and gasket matched with intake!Rest of combo is 727 with 2800 stall and 8.75 with 4.10 or 4.30 gear with 28in tire!Has anybody ran this same or close setup and how did it perform!Does this sound good for 1983 dodge d150 shortbed 2wd with 2.5 exhaust with dynomax ultraflos!
