[WANTED] SB 4spd bellhousing 5.125" or 4.807" index
DaveBonds
Garage Trash
Lakewood, CO
Just like the title reads.
I'm after a 5.125" or 4.807" index small block bellhousing.
I have a 4.354" bell and a 4.160 bolt circle on the case. I can make it happen if I have to, welding up the fork pivot holes and repositioning them to clear cutting the bell to a 4.807" hole, but I'd rather just get something that will do without cutting this bell and pass it along to someone else who can use a 4.354" index on their case.
do you know what casting number you need? i have one that might work it measured 5.088 casting number #3743859 LA A-833 10.5, 11 clutch 1974 E-Body Aluminum
Casting number 3743859 should fit 75/76 A bodies, 75 to 80 F bodies, and 76 to 80 trucks and B Bodies with the right clutch fork. Should have an bearing retainer index of 5.125 inches. This bellhousing was used behind overdrive transmissions.
What's your application?
pro3091, that is the bellhousing that I'm in the market for. would you be willing to ship it? if so whats your price? PM me if you would like to sell it please.
