[FOR SALE] SB 4spd bellhousing, Wilwood disc brake conversion, SB Milidon oil pan. Mopar Alley show delivery.
migsBIG
San Jose,CA
Free delivery to Mopar Alley Rallye car show June 10th at DeAnza College in Cupertino, CA.
Small block cast iron bellhousing. Looks nice and does not look to have any cracks. $199
Milidon pan with stock pickup. Pan is for 360 engines and won’t work with 318/340. has been on a motor for years and never run, but has pretty much has shelf wear. $199
Wilwood disc brake conversion for 1962-1972 b/e-body drum spindles. Has new everything, never used, 4piston calipers and uses vented 10.75 rotors to fit behind stock 15in wheels. $499
Sorry about that. It’s for a 360.
Update. Found the pan is 8 quart 360 pan with stock pickup. This is for car models and will clear most k-members and aftermarket subframes. $190
Reduced the bell-housing to $150
Disc brakes down to $450.
All will still be at the Mopar alley show. Willing to ship oil pan as it is light enough, but shipping is extra.
Are those brakes the drag light kit? I’m looking for something that will work with a big block b body for normal street use.
Great. pm me your phone number and when you get to the show you can pick them up there. Be early these are sure to go fast.
