gzig5
I would be using Durabar if I had my preference. It would probably need to be spliced together rather than carving it out of a single block. That would have some benefits, especially for cost but might make the design more complicated to keep the stability. After Durabar, some sort of alloy steel like Milodon uses.Would one made of steel expand at the same rate as the cast iron block? My design would be a lot different, it would not have the rail around the pan. Been thinking of this for 6 months now.
I was looking at making main caps for a 340 block and nobody seemed to think aluminum was a good idea but it is used on big block caps routinely.
