[WANTED] SB Bellhousing and flywheel
Ivoryk3ys78
Oregon
Looking for a small block bellhousing and flywheel. Wanting to be able to start and run the engine without having to use my 727 for diagnostic purposes.
Thanks a lot
I am not sure of everything as far as compatibility goes. This is for an early 360 engine with a 4" cast stroker crank.
I have a bell housing also, you will need a specific 360 Flywheel.
Thanks a lot
I have a bell housing and flywheel. I used them on a run stand. Flywheel is set up for forged or cast crank. Removable weight for either combination. I ran a 360 and a 340 with this combo. Located near Bakersfield Ca.
Thanks for the responses. Looking like me and Early A Bod are pretty set on Bellhousing. My dad is going to check the local junkyard for flywheel with so much shipping weight. Hopefully I will know how that goes by the end of this weekend.
Thanks a lot
Here’s pics of the bell I have
