340dartsport73
Member
Sbm comp cam xtreme energy mech. lifter cam w/matching springs $140 or b.o.
Fresh factory 360 cast crank. Stroked .030 and balanced. All bobweight info is there. $200 or b.o.
New mopar performance valvesprings, retainers and seals. Little bit of corrosion from sitting. $60 or b.o.
Sbm 1.5 ratio Harland sharp roller rockers w/shafts, spacers and shims-$480 or b.o
Comp titanium retainers, 10 degree keepers, drag roller springs and locators. $200
Sb mopar heads. All heads have been bead blasted, crack & pressure tested.
Front to back
1-#915-$50
1-Magnum-$50
1-#596-$40
Front to back
1-#915-$50
1-Magnum-$50
1-#596-$40
