Baxter61
Selling my good, used SB Mopar top end. This is a good set of heads and a good intake. Motor is coming out of car for rebuild this week (most likely tonight or tomorrow) then they will be available. Heads are 587 J heads, rebuilt, have 2.02 340 intake valves installed, bowl blended, gasket matched, milled to 63 cc chambers (if memory serves me right, could be 65 cc, can check when pulled), have aftermarket comp springs with 110 #'s on the seat, perfect for most hyd cams and some small solids. Intake is a performer RPM intake that was also gasket match. This top end performed very well. Took my street tired 70 duster with a 9.3:1 360 with comp xe284h cam and 3.91s to 13.35 at 103 MPH in the 1/4 with no traction (60 foots over 2 seconds) and no accelerator pump tuning on a 650 carb. The car weighs 3550 with me and a full tank of gas and using the MPH to power equation found at www.wallaceracing.com you can see that this equals almost 320 RWHP! Car would run in the 12's easily with a little track prep and some tuning. $600 for heads and intake, ready to bolt on! Have rocker arms for extra. And because the motor is coming out, I will sell the cam and lifter set as well. Lifters will be in order as removed from the block, only have about 500 miles on the setup and always run with GM EOS zinc supplement. $150 more. PM me on the board! Located in Oregon City, OR, I can get a shipping discount through work.
