[SOLD] SB LD340 Intake Manifold - Dial-up Beware, pics inside!
Baxter61
Oregon City, OR
LD340 Intake Manifold for 340/360. This manifold has been cleaned and painted. This is a good manifold, however as you can see in the pics it is not the greatest casting job. The water ports did not hold up like they should and there is one wonky part in an intake port. Even though I was able to grab good threads in all the holes and seal a water neck there are 3 things this manifold could use if you wanted it to be a little better: a heli-coil in 1 (maybe 2) carb stud holes, a heli-coil in a thermostat housing hole, and a little epoxy on the thermostat flange. Having said that this manifold is still good and did not weep water and the studs I used held torque on the carb quite good. $200 plus shipping from Oregon City, OR or local pickup. Shipping usually runs about $20 through USPS. Paypal accepted as gift or you pay the fees. PM if interested.
