[SOLD] SB Race Engine
Krooser
Building Chinese Free Engines since 1959...
Central Wisconsin
Rating - 0%
0   0   0
First I must tell you I will only deliver this engine 300 miles. You are welcome to pick it up in central Wisconsin.
70's vintage 360 block. .040 over. Fresh bore, new deck job and line hone. Block was o-ringed but the grooves are shallow after the machine work. It had Fel-Pro 1008 gaskets. The machine work was done by a good race shop in Eau Claire, WI.
New RaceTec 4032 forged pistons. Hastings 1/16, 1/16, 3/16 rings. Choice of Howards or Mike Jones custom cam. I have one set of flat tappets.
ARP head and main studs.
I have Howards valve springs and tool steel 1.290 springs and retainers. You get both.
Fluidamper.
I also have two methanol Barry Grant carbs...one 750 with a new 850 base plate and one 850.
M-1 intake port matched to W-2 heads. T&D 1.5 rockers on stands. No pushrods. New Manley. 11/32 valves. 2.08/1.6. Heads are ported. Intakes flow 294@.600 exhaust. about 190.
Crank has been repaired on the front journal. .030 on rods/.020 on mains. Crower rods.
King black bearings. Stock front cover. Race water pump. Aluminum pulleys. Plus more.
$6500. No trades unless it is a running b body.
I have taken some serious health hits and my race days are over.
PM me.
Rick.
could you post a couple of pics of the carburetors ? Any interest in parting out the engine ? thanks Red B.
BTW, Sorry to hear about your health issues, all the best going forward.
