WAYNE0
I have a 67 barracuda with a 360 in it. Is it possible to replace the rear main seal without removing the engine ?
yeah. you can do it in situ.I have a 67 barracuda with a 360 in it. Is it possible to replace the rear main seal without removing the engine ?
mmm never seen one like thatDone that and ALL the bottom end bearings before, that odd *** upper half with the tabs on it makes doing a rear main without removing the crankshaft impossible.
Hope you don’t have that seal.
Here's a couple videos I watched. YMMV. They're both trucks, might make a huge difference.
time to bust out the yoga mat or make do with the tijuana creeper!lol no lift no engine puller ill be laying on my back on cement floor
yeptime to bust out the yoga mat or make do with the tijuana creeper!
getting the room to work is probably the worst part of the job. pulling at least part of the steering is necessary. you may or may not need to lift the motor to wriggle the pan clear of the k, it depends on the pan and what pump pick up you have.
clean everything *spotless* and don't overtorque it going back together and you'll be fine.
