SB to BB Power Steering Brackets?
Ricks70Duster340
Child of the King
Sisterdale, TX
For those who have replaced their small block with a BB; can you tell me if the power steering brackets are the same or if I need to get BB ones? I currently have the Borgeson PS with Saginaw pump.
I’m not sure if BB and SB pulleys were the same either. Easiest to get the entire BB pump.
I don’t want to break forum rules but I have a couple I’m willing to part with.
Above , Totally Correct! All I can add is, I believe there are almost 36 different pulleys between Small and Big Blocks, in all various combinations of accessories.... It can get silly at times. So if You CAN GET an entire set up, off a known running, or not molested engine, that's the least aggravating way...
