[SOLD] SBM 727 10" converter
RPAGAN
Florida
ACC 10" streetfighter converter part #54095. This converter has maybe 100 miles and 8 1/8th passes on it. Flashed to 3400 behind a w2 headed 340. Not enough converter for this application. Went to 4200. Summit and Jegs get well over $500.00 for these. $200.00 plus shipping to lower 48 states. Ships from 34667.
ACC 10" streetfighter converter part #54095. This converter has maybe 100 miles and 8 1/8th passes on it. Flashed to 3400 behind a w2 headed 340. Not enough converter for this application. Went to 4200. Summit and Jegs get well over $500.00 for these. $200.00 plus shipping to lower 48 states. Ships from 34667.View attachment 1714963997
Interested. What does went to 4200 mean? Also, weight of car and estimated torque from motor?
Thanks,
JW
We switch the car over to a 4200 stall converter. The car weighs 3160 in street trim. Not sure on torque. the car has ran 7.24-93.27 in the 1/8th if that helps.
It may work for my application. You are making way more torque than I will be and lighter. I will PM you....
