[FOR SALE] SBM Ansen Blowproof Bellhousing $500
66fs
Greenwood, South Carolina
SBM Ansen Blowproof Bellhousing fits early A but will fit all small block MOPAR engines. Comes with Lakewood motor plate that will need minor modifications to use with the Ansen bellhousing. $500 + shipping
This Bellhousing takes the standard 340 clutch and flywheel with 130 teeth. It will also take any trans since the pilot diameter is 4.807 and needs an adapter ring to get down to the standard A Body 4.354. I'll try to update the listing later today and add some pictures. It will fit an early A Body, for example as I understand it, a Lakewood bellhousing does not. I'm sure you need the Brewers early A conversion stuff to use it in an early A Body.
