j par
Well-hung Member
Initially the purple performance cam that was in my 318 was taken to Ken and ground the base Circle and was set up with custom Smith Brothers pushrods to make up the difference and keep the geometry correct. This last time I ground the same cam again but not needing as much lift so there was no need for base Circle grinding.Jpar, what do you do about the base circle getting lower and lower? Do you have adjustable rockers?
I do have Hughes 1.6:1 roller rockers. Geometry is extremely close as in they're not adjusted out except for the minimal amount. As in these pushrods would probably be too long for a stock cam.
