SBP hubs and rotors available anywhere???
jeff_mopar
So Cal
I am wondering if small bolt pattern rotor are available anywhere?
Also, are small bolt pattern hubs and rotors available anywhere?
Thank you,
Jeff
Rotors are available new, but hubs are not. Bu they are not very hard to find, since so many people switch to large bolt pattern. There are probably some in the parts forum right now.
new rotors are no issue to find , hubs are not so easy , i'm not a were of the sbp hub reproduced . and the spindles are special also . are you liking for a set up of sbp disc's ?
Rotors are available from lots of sellers, vendors.
Amazon, Rock Auto, any parts store that handles, Wagner, Bendix, Centric, parts.
As far as Hubs, Those are the hardest things to find for the Kelsey Hayes, 4 piston, disc brake systems.
Used only, and good luck finding them, in this day and age, if your looking for them, needing them.
Getting to be unobtanium, dinosaur eggs, hens teeth, to come across these days.
ya if you find them and buy them , just hope you get them . i've been involved in four setups , and half were good deals and well one setup still hasn't arrived yet . if you looking for some , read my thread ' wtf is up with these members here ? ' it might keep you found getting screwed .
What would you guys think a set of hubs and rotors are worth?
You can get rotors priced from 25.00 to $40.00 each these days, it seams.
As for Hubs, somebody that knows what they are going for these days, $100.00 to $125.00 for a pair is not out of line.
The last pair that i had in my inventory of parts, went out the door at $120.00.
Once, in person, years ago.
No problems and got a good deal.
He sells parts from time to time on CL and here, but not real active in the local Mopar crowd I know. He seemed like a pretty normal guy to me, didn't strike me as shady, and never heard any other complaints about him.
would you call him or get with him about my purchase that he's just not sending to me . i could use the help with him finishing up our deal . i can pm you his info , please . i'll cover your costs if need be .
The stuff you want comes up several times a year on this site and on eBay. Last week on eBay: rotors, hubs, calipers, spindles, lower ball joints, hose brackets, and dust shields went for $193 (this was a good deal).
Typically prices for above used parts go for $200-$500. Then most likely you have to rebuild the calipers and get new rotors.
Finally, if you ever go north to Sacramento, talk to Hemi71x.
Converted mine from original Kelsey Hayes discs to Wilwood. The Wilwood rotors are dual pattern. If your concern is that you have SBP wheels and maybe want to run BBP wheels later this is your answer. Plus they stop a whole lot better.
I did pretty much what superchargeddrt did with the addition of QA1 upper control arms. I still the old setup and was going to sell it, just haven't gotten around to it. Here is the ad I was going to do:
"Kelsey Hays disk brake setup from my 70 Dart. Converted to Wilwood and manual master cylinder sono longer need this setup.
Includes everything except the spindle nuts that I used for my Wilwoods.
Things that should be replaced, ball joints, bushings and the rotors as there are grooves in them. Will need replacement passenger side brake line. Everything worked fine when I removed them from the car, wanted to go BBP and went this route.
Willing to part out as this stuff is pretty heavy and probably pretty pricey to ship. Located in San Diego CA."
If I can help you guys out just let me know.
Mods, know this isn't a for sale add, just tryin to help some folks out. If this is out of line let me know and I'll delete it.
@tjpatte , it does not have a price , i'm interested in your kelsey hays set up , all of it , spindles dust sheilds hubs rotors calipers and the brake lines with brackets . can we talk in pm about your parts . i would like to see pics , i can give you my email for that .
@tjpatte , your a great member here everyone should know about your deal you presented to me . he's selling me his old k/h setup . and sending it to me so i can look it over , before i send him the funds . what a great guy he is . you've restored my thoughts on people and the great things that can be done . thanks for being a straight up member here . just hope i can do the same for someone or you tjpette . thanks again . i feel free'd up and can get out of that hole , lol .
No problem Man, us Mopar guys gotta look out for each other!
Ain't like this is a chevy site!
BTW, you should get some of that shoring in place!
thanks i've refilled that hole in the earth already , that was a sewer cleanout install , that hole was over my head at the deepest , yes i do get into some shity work some times . wrench , hammer , shovel , paint gun . i can use them all . thanks again brother .
