Grasshopper
I have a 71 Scamp with small bolt pattern. I will be converting to front disc bakes. Currently I have 14 in rims. Will these still fit with disc brakes? If not what size/s rims (small bolt pattern)can I use so I can use with the disc brakes and add a slightly wider tire and use the stock hub caps? Any recommendations of where I can find? Thanks!
